Problem with Nokia Theme Creator and Themes.
3 replies · 12,607 views · Started 08 November 2004
Today when i download Nokia Theme Creator 1.2 and there were 2 Themes in between one was Grind II and some other i install both on my Nokia 7610 and use Grind 2. While using the Theme iif i create message and just click on the Green Button for sending message then the phone get off and the on (Just in the case of hang). This was happing in both the cases and when i use any other themes then it was ok. So i delete both the theme from my phone and i have 2 Question?
1.Why This was happeing?
2.If I create any theme this problem will carry on with that also?
For Elton: when elton my computer gave me some error and it was shutting down in 60 second and i have someseconds remain i just go on typing and didn't read.
Lol Vicky,
How the hell did you become a moderator with language like that????????
Do you mean by "when i send message and put send it suddenly get off when i put call divert it get off and many more time." that the theme crashes (removes its self)?
elton wrote:Lol Vicky,
Lol. Enough said!
Ian
Hi there,
the problem with the two themes in the themestudio only occur when you use the ones which came with the studio. They are corrupt. Nokia is informed about that and will change it in the downloadable themestudio as soon as possible.
If you open e.g. the surfer theme, edit it and create a new SIS-File, the problems will be solved. Only the old SIS-Files are not usable.
And newly created themes will also work perfectly.
Katolino
