Anyone has problems printing on HP4550
Nokia 9210 IR printing
I have not been able to use IR printing on the Canon BJC50 or BJC85 or the HP laserprinter series. In the system folder, you only see references in to print to fax. Maybe because I am on 3.18 or maybe Nokia just havn't loaded the printer drivers and havn't told anybody.
<TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote</font><HR></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR></TD></TR></TABLE>
About BJC 50, I think it is because of the software version. I have version 54 and I printed on my BJC 50 without any problem.
dorin
i've got a 9210 with sw version 3.54 but i'm unable to print with canon bjc85.
if i have a text to print ( i.e. the start here file on the desktop of the phone ) only the black part of the text will be printed, the colour ones remain white.
If i try to print a picture i've got the same problem, i can print only the black part of the image.
this occours to me either using the bj mode or the lq mode.
try using the (LQ) rather than (BJC) option
with these Printers. That worked when I try it.
Using v3.54 i've had no problems printing on the HP Laserjet series
