6600 Java/.jar Files
4 replies · 7,824 views · Started 09 November 2004
anyone know how to get .jar files to work on N6600? ive downloaded nokia pc suite to send the files but i cant get pc suite to find my phone. i also have a 6230 and a 7610 but pc suite cant find either of them. i was wondering if there was a different program that i can use to install .jar files on my phone. thanks ^_^
tgsbeast wrote:anyone know how to get .jar files to work on N6600? ive downloaded nokia pc suite to send the files but i cant get pc suite to find my phone. i also have a 6230 and a 7610 but pc suite cant find either of them. i was wondering if there was a different program that i can use to install .jar files on my phone. thanks ^_^
Use pc suite with your nokia 6230
open the "install" application
put the .jar files on your desktop and pc suite won;t see them
rename them by deleting the .jar extension
refresh
if necessary rename them back to the original .jar filenam and pc suite should find and install them
alternatively, use the "transfer files" app, put them onto the mmc card in your 6230 and then put that card into your 6600.
i can send the files normally to my N6600 but then my phone says unsuported file format.
on my 6230 i cant see my phone on nokia pc suite and when i send the files normally over bluetooth i get the same message saying unsuported file format :/
tgsbeast wrote:i can send the files normally to my N6600 but then my phone says unsuported file format.
im having the same problems to i dowloaded a java game @ mobango.com after downloading it i trnsferd it to my phone using PC suite,but when i tried opening it same thing comes up "unsupported file" pls to all knowledgable out there help us out. what is it that im doing wrong? should i download an application so that i can open the file out? i have zero knowledge about JAVA .jag file. by the way my phone is a N 6600
