Any way to use DKU cable on Win 98?
6 replies · 1,887 views · Started 09 November 2004
I only want to transfer files (i.e photos) but the nokia pc suite provided doesn't work on anything below win 2000.
No way. At best, try to find a Bluetooth adapter with Windows 98 support and use simple file transfer, or get an MMC reader with Windows 98 support, or upgrade your PC (or at least Windows).
Thanks for the help. I've tried a bluetooth adapter with no success, and I now have an MMC reader on it's way to me, so fingers crossed that it'll work!
Doesn't help at all, because PC Suite for the 7610/6670 (v6.2-v6.4) doesn't; the cable driver alone is not enough for doing anything useful.
Yeah, the cable works, but there's no software, not even any third party. It would be helpful really if Nokia provided just a simple file transfer program as well as the PC Suite 6, as I didn't want to use any other features on it.
Voor wrote:Yeah, the cable works, but there's no software, not even any third party. It would be helpful really if Nokia provided just a simple file transfer program as well as the PC Suite 6, as I didn't want to use any other features on it.
It depends on the phone type. There is PC Suite 5.8 that works under W98ME/SE, but it doesn't support newer types like N7610 or 6670.
http://www.nokia.com/nokia/0,,54698,00.html#model
