Is it like this for you ?
1 replies · 968 views · Started 09 November 2004
I gues it�s only a setting or something but I haven�t been able to fix it myself.
When I play a game, any game, and hold down the direction button to any direction it works good for 1 sec, then it start to lag real bad. It�s like a repeat function or something I gues when you hold down the button. I can hear a smal button press sound repeating itself. This lag it creates when playing a game makes it totaly unplayable cause I have to release the button every sec.
Anyone know what the reson for this is �?
Tnx
~Majstro~
if you put the phone on silent or vibrate mode it'll fix it.. it seems to lag when playing the button/screentap click sound.. perhaps you could also disable those sounds,.
