*.jad & *.jar files
7 replies · 4,530 views · Started 10 November 2004
HOw do you install *.jar and *.jad files they are all confusing!!!! As when i download the free games from net it are in *.zip form what should i do let me know
I have the exact same probloem. I can install them with fexplorer but down know where they go!~!!~!
They (Java applications) go in the "Apps" application (on the N-Gage and other devices based on Series 60 1.2 or older).
i downloaded a game lat night and its in the .jar format..... what program can i use to install it?
wghhtuy wrote:U Could use fexplorer
where should i placed it? (*.jar n *. jad) at the root???? thanks
No need to place the .jad files anywhere. If you launch the installation with an app like FExplorer, put the .jar files anywhere you wish. If you use the [Application] Manager app, then the memory card root should work (with the N-Gage, at least).
First of all u have to download Fexplorer from the internet.its an application acts.works very well.download it by doing a google search.then download the .jad or .jar files.once u have done this.go to E: in fexplorer appliction and keep scrollin down till u find the application u want to download. Cheers!
