New user & Error with MMS and some bugs...
2 replies · 1,858 views · Started 10 November 2004
Hi All,
I'm happy to jon this great forum!
Three days ago, I bought a Nokia 3650 phone from a friend, It has verison 3.16 of firmware. I did a full format of it and installed my GPRS profiles, clock, cam corder... etc. It works fine EXCEPT:
1- When I want to send a new MMS or go to MMS Settings, it shows "Messaging: System Error"! and refuses to continue, but the phone doesn't hang.
2- When I use my custome MIDIs or WAVs, Viabration alert dosn't work although it's enabled for the current profile! it works only when using pre-installed nokia rigngtones!
Can you help me? they are two very annoying problems! when I tried to format my phone for the second time, it only reset the settings, but all files and images stayed as it's!
Is all of this a bug with the firmeware? or something can be done by me to fix it?
Thanks so much!
How did you format your phone?
You might be best off, if you have a Nokia authorized service center put the latest firmware release on it. The version you have is very old.
N/A wrote:How did you format your phone?
Hi Thanks a lot for your reply, I formatted it using *#7370#
So this is a bug with the firmware? I'll need to travil to another city to go to the service center, so I was looking for a simple solution -if any-.
