MMC error
2 replies · 1,827 views · Started 11 November 2004
I just bought an Apacer 256MB MMC for my 3660. it shows "mmc corrupted, format now?" i said yes, then after the progress almost finished is said something like memory error or something. i tried the mmc with my pc card reader it works perfectly.
i have the same problem last time with the 32mb mmc. fixed it by formatting with the card reader. I even tried to reformat the 256 with the card reader, still the phone cant reconize the mmc.
I know someone with the 3660 using the same brand and it works without any problem :con? i dont think the mmc is bad because it works perfectly fine with my card reader. I cant test it on another device yet
I have the same problem too, i formated my mmc in the card reader then it works fine w my 3660 be sure to format it with fat not fat32 coz i experimented with it already and the fat32 is not recognized by our 3660. format it with fat only not fat32. After u format it create a folder named system and inside it create another subfolder called apps and im sure it wilk work!
