The story has .....
I send this e-mail to
> Dear Sir's
> On 10-11-2001 you send me the reg key for Time Tool prog. I had buy that
> with credit card from ShareIt! i think.For some bad reason my Nokia 9210 has
> a start up problem and i send that to Nokia Service.
> Because the problem it's not simple the Nokia give to me a new one. Because
> i have not a copy of reg key for the Time Tool in a safe place but only in a
> text file on my nokia , and also the e-mail from you, on it, i loose them
> with lot of data. It's a posibile to send me one more time this reg ? If not
> i send you again my credit card data to charge me again the price for that
> prog. For security reason if you like i send you some number of my credit
> card to recognise me.
> Name Chrysanthos Vasilakis
> Card Visa xxxx xxxx xxxx xxxx
> e-mail [email protected][email protected]</a>
> For any info contact with me.
> Thank you for you time
> Best regards
A few hours ago i receive the answer.
-Your key is xxxxxxxxxx
-Regards
-D. Lausecker
-http//www.timetool.de
What can i say...
Thank you Mr D.Lausecker
Chris
