Do you make data calls on your 92x0???
3 replies · 2,462 views · Started 11 October 2002
This thread included a poll: What data access do you use on your 92x0?
In the spirit of Polls, I'm kicking off on, heres another. You can make data calls on your 92x0 these are primarily for WAP/WEB access, which do you use, if either. Also there's the option of checking your e-mail or using an IM. If you look at the page cast a vote, only takes a second 😊.
could you add a e-mail/web option 😊 I think that would be a pretty obvious choice, isn't it? 😊
[quote="Dazler"]could you add a e-mail/web option 😊 I think that would be a pretty obvious choice, isn't it? 😊[/quote]
Absolutely
