"GO TO" folder on a 6600
3 replies · 2,191 views · Started 11 November 2004
I've recently bought a nokia 6600 from an orange user and there's a load of files that I need to get rid of. I did a hard reset which sorted most of it but there's a load of shortcuts in the "GO TO" folder that I can't remove.
Does anybody know how I can delete them?
Which shortcuts, exactly? Some of them cannot be removed (Calendar, Inbox, Notes by Nokia, and possibly some fixed there by Orange).
How to do what? Remove shortcuts that are removable? If that's what you mean, then select one, hit "Options" and the rest should be obvious.
