Does anybody know some information about Nokia 6630 and Nokia 6670's processor speed and RAM? i need to know these things so I can decide which one to buy. Thanks!
Question about Nokia 6630
michaelglim wrote:Does anybody know some information about Nokia 6630 and Nokia 6670's processor speed and RAM? i need to know these things so I can decide which one to buy. Thanks!
The nokia 6630 processer is a 220MHz... 😎
try to look at the older topics,because i remember,that someone posted an short review,and there was some information,and as i know,the processor is running on 220Mhz 😃
Thanks guys! but how bout nokia 6670? do you have any idea bout its processor speed?
Same as 7610, about 123MHz.
N/A wrote:Same as 7610, about 123MHz.
you're wrong, the 6630 runs at 220Mhz, and has 10MB of internal RAM + a 64MB RS-MMC
He was referring to the 6670, NOT the 6630
michaelglim wrote:Thanks guys! but how bout nokia 6670? do you have any idea bout its processor speed?
all parameters and features are the same in 6670,than in 7610,the only difference is design /keyboard/,but the other things are the same /same resolution,processor,ram,and so on/
for 6630 and 6670 performances and other technical data, try to give a look here, in case you don't know this site
