I want to update the firmware on my X, but when I go to the SENDO website and follow the procedure it tells me to use the number under the battery. None of the options listed are relevant to my phone: 8YOH - 01172 - 4X000 is the number under the battery. this is on Voda contract.
Can anyone help please or does this just mean that I have the latest firmware installed already?
Cheers
I've just got mine from Vodafone too and have exactly the same number under my battery.
As far as having the latest version of firmware installed, people on this board have been saying that some expansys phones have a later version installed.
I think i have that correct - someone should be able to put me straight if i'm wrong!
Struyk wrote:I've just got mine from Vodafone too and have exactly the same number under my battery.
Thats right!
Expansys has an older firmware version as they released prior to VF.
The VF version that came with the phone is very good and approved by VF. There is no firmware update on the sendo site for VF units at the moment, and to be honest it's not needed unless you are having problems.
Infact, the Expansys firmware is newer than the Vodafone firmware.
