Streng nokia 7610 problem
3 replies · 1,447 views · Started 12 November 2004
I have problem with my new Nokia 7610:
When I open it ''Main app closed'' is appearing and then I can not
do the follows:
a) Open tools to see and manage the apps (is displaying scanning memory and stays there).
b) When I go to gallery, I can only see the phone's files. When I try to see the memory card's files, the phone returns to menu position.
c) When I put a new app via my pc, the app is working until I turn off the mobile. When I turn it on, the app dissapears (also I can not reach app from tools menu).
Can anyone help me to overpass this problem?
I already formated my mobile but nothing happened!
Remove Your MMC then try if still not satisfy the you have to do Soft Format.
It will Set to your orignal phone files and settings
If not work Format Both MMC AND PHONE
