Good day to all.
Agile Messenger v3.13 has a PTT feature. Has anybody used these on their P900? If so how? Tks
Agile Messenger PTT feature
I've revisited AM site today and found my answer. Now all i need to do is try this PTT feature.
du7m wrote:Good day to all.
Yes, I use it and it works fine on my P900 -- simply use the button under the "camera" button on the right side -- hold it down, talk, and when done talking, let go of the button -- it'll send send the voice ...
Thanks Praefectus.
I tried using the PTT and it works fine on transmit. I havent tried the received though as the link on the other side is using a desktop. I presume that the receive works if the other end is also using a cellphone.
du7m wrote:Thanks Praefectus.
Of course, it's made to receive from another Agilemessenger phone -- it will then play automatically or you can set it to just play when you click on the message in the chat pane. You can send to them (voice / pictures) if they're on a desktop, but naturally they can't send back to you without Agile....
Also, if you want to test it, give me a name on Yahoo, MSN, ICQ, or AOL, and I'll send you a message when you're online -- I normally use it with my friends ok....
