Hey i have just bought a sim free 6600 and i stuck my vodafone payg sim in it. Ive had the gprs settings sent to my phone countless times from the vodafone website to no effect. I cant send mms or use opera to browse the web can someone advise me on some working settings? The tariff is smartplus if that helps any 😊
Thanks in advance
mms settings are not the same as internet - to get "proper" internet access you will need Voda to remove the restiction that is on - this means accessing via VODA GPRS ISP rather than VODAFONE GPRS (which is actually via a wap filter). You will have to give them a ring and you will also require a credit card to verify you are over 18.
http://www.nokia.co.uk/nokia/0,6771,60344,00.html
for your mms settings
I thought they would have sorted this by now (and they may have) but i got my 6600 over a year ago and downloaded the settings from the vodafone site,and they didnt work! They assumed the settings would be the same as 7650 but they are not. In the end i got all the settings i needed from this very site including internet and mms,so do a search for "vodafone 6600 settings" and you should find the page which includes the voda settings and manual input instructions.
Good luck :icon14:
Thanks Guys, im gonna do some searching on the forum. I did the mms thing from the nokia site and it still dosent work :con? I guess i should call them or take it to the nearest vodafone shop if i cant get it to work.
Alex
Edit: ive dont a total format of the fone, now when i try to access a wap page i get a flashing G in the top left corner of Opera and then nothing. Same thing when sending a mms, i get a lil flashing g in the corner but its complains and tries to resend in another 5 mins 😡 Maybe i should just change to another sp?
Alex
