I just want to know if I can buy the Nokia 6630 overseas and use it in the US. And are all Nokia 6630's in English? And if anyone knows at all where the Nokia 6630 can be purchased online (Not pre-order) that would be great, thx
Nokia 6630 questions...
The 6630 should work in North America when there is a GSM/GPRS carrier that supports 1900MHz, or a WCDMA carrier. It will not work in those regions where a GSM/GPRS carrier only supports 850MHz.
All variants should have English + one or more additional languages (depending on the region it was manufactured for) support built-in.
Does T-Mobile support 1900mhz?
AsILayDying wrote:Does T-Mobile support 1900mhz?
try to look at the american site of T-Mobile,there you maybe find his information 😃
