Removing Symbian Software from N6600
13 replies · 3,448 views · Started 15 November 2004
I'm looking for a way to remove installed symbian programs on my Nokia 6600.
Tried googling it but found no real answer. Somebody outthere who knows ?
Thnx Lupus
I did read the manual 'Dog' and no help
That's why the question.
If anyone has an serious answer, it's much appreciated
Thnx
lupus wrote:I did read the manual 'Dog' and no help
Thnx
Search nokia 6600 forum.
Let's say that I'm really stupid and that I can't find a way to remove programs from my phone's system, could anyone tell me or lupus exactly what application should we use? Not anyone is as smart as you are.
Thank you!
Read the phone's User's Guide and the "Application Manager" part of it. In other words, run the "Manager" app, select the program you want to remove, hit the "Options" key, select the obvious option (hint: "Remove"😉.
lupus wrote:I'm looking for a way to remove installed symbian programs on my Nokia 6600.
Thnx Lupus
What program is it you're trying to uninstall?
First things first....
(1) MENU (the button right below the button u press when you want to call)
(2) MANAGER
(3) SCROLL & FIND THE PROGRAM YOU WANT TO UNINSTALL
(4) OPTIONS (the lil button to the left of your joystick)
(5) SCROLL DOWN TO FIND "*REMOVE*" & CLICK...
That should do it...
*But you have to keep in mind that there are programs that you can not uninstall actually. Hehehehe!!! Believe me!!! I had to reformat my phone to get rid of those kind of progs. 😊 *
And for those progs that you can't seem to find answer to unistalling, There might be other ways to unistall it beside reformatting, but I have never found it.
Wish you all the luck. 😊
Wirelessly posted (piss: Nokia6600/1.0 (3.42.1) SymbianOS/7.0s Series60/2.0 Profile/MIDP-2.0 Configuration/CLDC-1.0)
psihotrop wrote:Let's say that I'm really stupid and that I can't find a way to remove programs from my phone's system, could anyone tell me or lupus exactly what application should we use? Not anyone is as smart as you are.
Thank you!
You can use APPMAN then close all application then finds app manager and select remove that your application u want to remove,if it does't work use Fileman go to system,app then delete that application.
Thank you!
Thnx
If you want more detail about how to remove that application? you can
piss wrote:Wirelessly posted (piss: Nokia6600/1.0 (3.42.1) SymbianOS/7.0s Series60/2.0 Profile/MIDP-2.0 Configuration/CLDC-1.0)
Thnx
Sent me email to [email protected]
Thnx
Sent me email to [email protected] äbout your problem
Thnx
