FE Explorer!!???
7 replies · 3,738 views · Started 15 November 2004
Yo ppl! i got FE Explorer! got a few probs!!
1. I put Screenshot mode ON and it says to press "ABC" and "0" to take a screenshot but i cannot seem to take any screenshots! :con?
2. i have recived a mp3 file thru bluetooth and it is in my inbox and i cant find it with FE Explorer and not with my pc either!!?? where is it!!?? :frown:
pls help and tnx for u help in advance!
I believe the 'ABC' key thingy is related to the N7650 only..... Not sure about the zero '0' key-press.
If your message memory is set to phone then using FExplorer......
go into C-Drive / System / Mail / 00001001_S / You'll now have a few folders to look in... Named Usually 0,1,2,3,4 etc. (Some Will Be Empty) enter into each folder untill you find the offending file.
Hope this helps,
Paul (UK) 🙄
http://www.kv5.co.uk
why do you think you're not taking any screenshots? by default they are in c:/nokia/images/FE_img
casue wen i actually try and take a screen shot, i press 2 and 0 on the keypad, and when i actually go into the folder that it is supose to go in there is bo pictures there what so ever! and i press 2 casue it seems like "ABC"!!!
kvfive wrote:Press The PENCIL key (Hold it down then press zero).
to explain this; there was no "pencil" key in the 7650 / 3650, rather, it was an "ABC" key.
actually it was only the 7650 that had the abc button the 3650 the and the ngage (original) and 7610 has the pencil button, by the way i have had all these phones 😃 love symbian!
