Problem with uninstall
4 replies · 1,780 views · Started 15 November 2004
Hey
Last week i bought the p910i and now i put some apps onto it, everything worked fine until i wanted to uninstall an app. But it doesnt appear in the memory manager, so how can i delete it? (Its called soldierAnts, if that helps)
Paule
KayonLord wrote:Go to applications
Click on applications then click on Uninstall, select it from that list. and bingo!
I think i didn't express my problem properly: If I click on uninstall the programm doesn't appear on that list. All the others do but tis one doesnt. Is there any other way to get it of there?
Paule
