does anyone know if the wireless keyboards for PDAs work on the 6600?
I've got a "Belkin Wireless PDA keyboard" at home, and I was wondering if it'll work on my 6600...
http://catalog.belkin.com/IWCatProductPage.process?Merchant_Id=&Product_Id=144042
Has anyone used it before? If so, can you please tell me where you can find a driver suitable for this for the 6600?
TIA everyone! 😊
Basically you need a driver for the keyboard to work, I looked at the page you pointed to and it seems that it doesn't. I wouldn't choose an IR one myself as the port is on the side off the phone (there are apparently ones that get around this by having a movable transmitter) and it takes more power. There are BT ones available, and there is the Nokia one coming out sometime.
Example BT keyboard
I haven't tried any myself but I am considering one.
Has anybody had a go at trying to connect the Nokia Wireless Keyboard to the 6600? Nokia say its not compatible. Only 3230, 6260, 6630, 6670 and 7610 are supported. In an article I read that HID (Human Interface Device Bluetooth profile) is required. Does the 6600 have that?
The 6600 does not have Bluetooth HID profile built-in.
can you get this in a software or something or is it hardware/flash thing etc???
It is a hardware thing, the same as the audio profile was left off the chip for the 7650.
