I purchased the registered version of Psint Screen Saver.
It was fantastic as now I can have animated screen saver.
But the problem I had is that sometimes, the default screen saver will clash with the Psint Screen saver. Meaning 2 picture at the same time. Or rather the pictures were distorted.
Anybody else encounter the same problem.
Is there a way to disable the default screen saver from appearing.
I am from Singapore currently using 3.12 FW. Was it a bug?
Any news for Singapore 7650 to be upgraded. I had called Nokia Care but they say there is no such upgrade at the moment.
Please advise.
Thanks.
The latest FW is 3.16 in Singapore. I upgraded 2 weeks ago. U can call the service center to confirm before going down. I upgarded at Accord Distri center. Great service fromthe guys there.
Thanks....weekong
[quote="Anonymous"]The latest FW is 3.16 in Singapore. I upgraded 2 weeks ago. U can call the service center to confirm before going down. I upgarded at Accord Distri center. Great service fromthe guys there.
Thanks....weekong[/quote]
Thanks for the info man!
Will go down tomorrow.
But got a question here. Will they erase everthing from my phone.
It has taken me lots of pains to key in the contacts and setting up and etc.
Do they backup when they upgrade my phone?
I suggest you synchronize them with your computer, then if there was a risk of losing everything, then when your finished, sync back and...... viola!
However if you ask them to backup your data there they probably can do that! Their backup is way better than that you can do, but be aware!!!!
You MUST make it clear to them that you dont want to loose any information! Its important! Trust Me!
No i don't think that they will do the backup. I requested that they do it but they only say they will try. In the end it is back to square one. I suggest that u store all yr number in yr sim card and do a backup on yr pc.
Thanks.....WeeKong
i had a friend whose 7650 that unable to on after brought for a few days. she took to the nokia care centre at suntec, they are able to backup everyting for her and upgraded the sofware 3.16 at the same time.
