Hey ppl! im tinkin of gettin a new memory card! (256 MB) is it compatible with N7610? really hope it is!
tnx!
KaZ
tnx!
KaZ
Nokia says that 7610 can support up to 512M RS-MMC. But I don't know whether it will or not since I haven't try it.
In further, I doubt that 7610 can support 1G RS-MMC
Compatibility depends more on brand than phone - so, try before buy. 😉
Why do you think 1GB RS-MMC's wouldn't be supported?
Nokia doesn't guarantee that it will works. There is no documents stat that it can support also. But however the best way is to try the 1G RS-MMC & post in the forum here whether it can support or not. Brand of the MMC also matters.
I just purchased a 1GB card and it is already full so... I am actually thinking of buying a 2GB card as it apparently also works on the 6670/7610... anyone have a 2GB card that is working?
jes it is compatible i had a 256 mb card now i purchase a 1gb
