Series60 Tools Folder!!!!!?
8 replies · 2,114 views · Started 15 November 2004
Hi every body
I am new at this forum and I am at the start of programming for Symbian platform...
I have download the wanted SDK from forum of Nokia ... and in its related documentation it is mentioned that there are tools permits easy developing environment in the folder ( Series60Tools ), but this folder does not found at all in the SDK after installation, only folders: epoc32,epoc32exe,series60doc and series60ex are found ...
What can I do to get it , is there a link to get it or is there an ability from anyone to send it as a .zip file???
Which related document, exactly (filename)? On what page (if one of the PDF files)? Otherwise it is very hard to figure out what, exactly, you're referring to.
The Getting Started.pdf in the SDK documentation
it sayes that the components of the SDK are shown with given figure:
Attachments: SDK.jpg
Thanks. Now it is clear what you're referring to.
It (the folder or any tools) doesn't seem to exist in SDK 1.2. In SDK 2.0 it does, and there's "mbmviewer". In SDK 2.1 there's also "environmentswitch"
Ok thanks for your interest...
Can u send me the folder as a .zip file ... I need it improtantly and u will make a favor for me because I download SDK1.2 and I thought I will get these tools and it is difficult to me to download another SDK
my yahoo ID:
[email][email protected][/email]
Thanks...
There is no Application Wizard folder under Series60Tools; just mbmviewer and environmentswitch (at least on Borland and CodeWarrior versions of the SDK, I don't know about the Microsoft Visual C++ version). Nothing more.
