Hey ppl out there,can u tell mi is there any web link frm where i can dwonlaod the levels 12-21 of bounce to my comp and then transfer them to my 9210i instead of using GPRS to directly download it to my phone?
Level 12-21 of Bounce in 9210i
It appears that they are still available on the Nokia web site but are not easily accessible from the links. Series 60 versions of the levels are also available
but do not try mixing Series 60/Series 80 versions of the levels as they are
not compatible.
Bounce Level Pack 1: http://www.nokia.com/games/92xx/files/level_pack_one17.5.01.SIS
Bounce Level Pack 2: http://www.nokia.com/games/92xx/files/level_pack_two17.5.01.SIS
Download using the above links using a PC and transfer to your phone using PC suite and install to the memory card.
Installing the above SIS files gives you the bounce levels up to 21.
Question:
Has anyone produced a guide for Bounce?
The layout of the levels of slightly different between Series 60/80 -
anyone know the differences in detail?
I wish Nokia would produce more sets and also make the sequal 'Bounce Back' more readily available - we want to buy it but it's only distributes through the mobile operators own websites - therefore it's country specific.
David Moore wrote:It appears that they are still available on the Nokia web site but are not easily accessible from the links. Series 60 versions of the levels are also available
not compatible.Bounce Level Pack 1: http://www.nokia.com/games/92xx/files/level_pack_one17.5.01.SIS
Question:
anyone know the differences in detail?I wish Nokia would produce more sets and also make the sequal 'Bounce Back' more readily available - we want to buy it but it's only distributes through the mobile operators own websites - therefore it's country specific.
