Hello !
I have a JavaScript based Webpage to display the pictures of my webcam.
It perfectly works on any computer.
But it won't open on my P900. Here is the entire code :
// JAVA Code
import java.awt.*;
import java.applet.*;
import java.net.*;
// Variables:
// Trace - trace control
// URL - Url for image
// Interval update interval
public class JavaCam extends Applet implements Runnable
boolean boolean_Debug; // Debugging enabled/disabled
Image image_WebcamImage; // Image from Webcam32
Thread thread_This; // Thread for refreshing image
double int_Interval; // Interval between image refreshes ...
public static void main(String args[])
System.out.println("Webcam32's JavaCam: V1.1"😉;
public void trace(String message)
if (boolean_Debug)
System.out.println(message);
public void destroy()
trace("Applet.destroy() called"😉;
thread_This.stop();
public void start()
trace("Start called"😉;
thread_This.resume();
public void stop()
trace("Stop called"😉;
thread_This.suspend();
public void run()
trace("run(): Thread started!"😉;
while (true)
try
// Put the refresh thread to sleep for the supplied interval
Thread.sleep((int)int_Interval*1000);
trace("Flushing image"😉;
// Flush the image in the image buffer so we get a new one
image_WebcamImage.flush();
// Track the image and wait till its loaded
MediaTracker mediaTracker_track = new MediaTracker(this);
mediaTracker_track.addImage(image_WebcamImage, 1);
mediaTracker_track.waitForID(1);
// Repaint the image
repaint();
catch (Exception e)
trace("Caught:"+e.toString());
public void init()
String string_Url;
URL url_Webcam;
int int_Port;
boolean_Debug = false;
if (getParameter("Trace"😉 != null)
boolean_Debug = true;
trace("Init called"😉;
string_Url = getParameter("URL"😉;
if (string_Url == null)
showStatus("No URL for Webcam32 image supplied"😉;
return;
try
int_Interval = Integer.parseInt(getParameter("Interval"😉);
catch (Exception e)
// Format exception ... default interval 30
int_Interval = 30;
trace("Refresh interval="+int_Interval);
try
url_Webcam = new URL(string_Url);
trace("Target URL="+url_Webcam.toString());
image_WebcamImage = getImage(url_Webcam);
catch(Exception e)
trace("Image get exception:"+e.toString());
showStatus("Problem getting initial image: "+e.toString());
return;
int int_Width = image_WebcamImage.getWidth(this);
int int_Height = image_WebcamImage.getHeight(this);
trace("width="+int_Width+" height="+int_Height);
resize(int_Width, int_Height);
// Create and start the new thread initially suspended
thread_This = new Thread(this);
thread_This.start();
public void paint(Graphics g)
trace("paint()"😉;
if (image_WebcamImage != null)
g.drawImage(image_WebcamImage, 0,0, this);
// End of JAVA Code
// HTML Code
<html>
<head>
<title>WebCam Jonath !!</title>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
</head>
<body bgcolor="#FFFFFF" text="#000000">
<p align="center">
<APPLET code="JavaCam.class" codebase="<my website address>/"
width="320" height="240">
<PARAM name="url" value="<my website address>/capture1.jpg">
<PARAM name="interval" value="1"></APPLET>
</p>
<p align="center">
</p></body>
</html>
// End of HTML Code
I won't display the real address of the page on a forum, this is why you see the <my website address> thing ...
Here you are ... Any idea folks ?
Thanks in advance
Jonathan
