PDF Reader for A920/A925
4 replies · 3,506 views · Started 16 November 2004
Does anyone here know any good PDF Reading program for the A920 or A925? I have been looking everywhere, and I only found PDF+, which did not work for this kind of phone.
Eldritch wrote:I have that file.. it did complain that the program was not compatible with the phone.
Ok. Well, it worked for me. Maybe you could try upgrading to the latest firmware if you're not already running it.
I have the latest firmware. Must be something else... hmm.
I don't have to put the PDF+ .SIS-file in the same folder as that P800 file do I? I tried that, and the "Install Program" could not locate the installation file for PDF+.
All it does is say that PDF+ is not compatible with my phone, and then, after the installation, it says that it cannot locate the program when I try to run it.
