Hi!
If I send you some pics from Manowar themes, could you use them to make a skin collection?
Regards!
Hmmm.. I think this post belongs to Multimedia forum. Sorry.<font size=-1>[ This Message was edited by Manowar on 2001-12-08 1744 ]</font>
Hi!
Regards!
Thanks! ![]()
I�ll send some pics to your mail. Also I�ll send you a display.mbm file for you can see what I want,more or less!
This mbm file is only a trial file, 100x200... you know.. ![]()
Regards!
BTW, Loony... for what display.rsc is used?
Regards
It�s the file that goes into C\system\controls and owerwrites the default there.
Now you have custom text in the display control panel instead of the usual wheels, leaves, ect, ect.And the function itself is now called "Manowar Patterns" Pretty nice ![]()
All you need is a hex editor to make the changes in the original file..(by replacing the excisting letters with your own).You can even customise the text for all of the display controls..like i did... ![]()
Just shout and i�ll try to help if any problems..
(Oh...Rafe..Can this little topic find it�s way over to the MM section.?I think we are gonna fill a bit more on this one, as well as in the upcomeing userguide
cheers and Merry Merry Christmas
