Anyone tried the updated World Clock Pro which allegedly supports sound alarm? I can adjust the handy sounds (not the midis and wavs), but it doesnt work with my 7650: the alarm beeps as usually nevertheless ..................................... 😞
I dont need a world clock, I would like to have a simple alarm application which supports all stored sound files, repeat and multi alarm, not more!
I am having the same problem...I can assign a tone to an alarm...however, the default Nokia one plays! Psiloc, help please. :-?
Hello,
There is a next beta of World Clock Pro available (1.16B) - please try.
You can try also beta version of Extended Profiles Professional - with this application you can assign sound file to all clock alarms (also to calendar alarms).
PsiNT
Have installed the latest version 1.16...but have the same problem 😞 It still rings with the Nokia tune...
And problems are going on, even without World Clock: After removing the trial version from the phone, the phone still rings each day at the time I had set the alarm with World Clock to try it ... and I cant turn it off! ........ 😞
guess this was the last time I tried software from this developer .. had problems with Task Manager too before ...
Hi Freddie,
Nokia 7650 support 8 alarms (but built in Clock application can set only one), more alarms are supported by World Clock Pro and System Tools applications.
Please install any of above applications and remove unwanted alarm.
Rob
BTW Please send comments about BETA versions to [email protected].
Ok thx, I will try this 😊
Ok, this worked ... but one question: There must be a file remaining after deinstallation .. not only the alarm, but location and other settings are still there - where is this file located and whats its name? I want to delete it.
still can't change alarm tones
