SXI latest real player ?
6 replies · 8,063 views · Started 17 November 2004
Hi every one this is my first post here,
my SX1 firmware version is "svn:06 120 12004 appl sw:12.2_06" and battery standby time is maximum 1 day with normal usage and hangs on some occasions and feel a little bit slow while browsing menu.
so my question is if i upgrade my firmware to svn 14 can i increase my standby time and menu browsing speed? and any new thing in this firmware like new music player ,new camcorder,new real player etc.
and speaking of real player wat is the latest version of real player for sx1 and from where to downlaod?, mine real player is version 3.1406b 07-sep-2003-01:17:19
thanx in ADVANCE
[email][email protected][/email]
I have the same firmware version as yours and my phone could last up to 2 days with normal use so there must be something wrong with your phone. Try reflashing the firmware if possible. On the realplayer, just go for helixplayer. It has a lot more features than realone. Search for it in the forums.
Hmm.. depends on how much you use it, what apps you have running in the background, whether you are using a screensaver .... it's a combination of things .... also how's your signal strength? SX1 Battery just gets sucked out in weak signal areas.
no screen saver ,no fscaller , no extended profile etc nothing is running in the background and signal strength is excellent just one bar short of full,but again battery times only one day with version 6 swn.
from where can i get svn 14 or 15 ,in the siemens site it is only available version 12 for download. :redface:
