How do I set my ringtone to something I've downloaded?
3 replies · 3,423 views · Started 17 November 2004
Can anyone please tell me how to set my ringtone to something I've downloaded? I've just got the phone, and can't seem to figure it out.
I have the same problem, would appreciate any comments ...
Is it done by copying to a special directory or something else ... ?
thanx, navit
mp3 ringtones are not supported but wav files are. I use audacity to convert mp3 2 wav. When converting them, use IMA ADPCM codec at 22,050 kHz, 4 bit, mono. Then copy the file into the sound directory of your mmc card. I had to create the folder 1st
:icon14:
Dear,
You can use MIDI,WAV & AMR Files for Ringtone.To do this copy ringtone files to:
e:\sounds\Digital (in your MMC Card-if this folder doesn't exist,you can create it &
copy files)
You can use QuodRings to set an OGG file as a ringtone.
QuodRings Currently Support OGG Files only.
Good Luck.
