The battery life indicator on my 6600 is not refreshing itself. It always shos a full bar status even if the battery is about to run out. It only refreshes itself if you switch off & on the phone. Any idea why ? Is the the battery or the phone ? :dontknow: :frown:
Battery Life Indicator
Hard to say, but I'd try and borrow another battery and see if that performs any differently, if not, it's more than likely the phone. Formatting, if you don't have too much stuff to lose at the moment, will probably clear it up if it's a software thing, it sounds like the phone isn't 'polling' the battery like it's meant too.
If a format doesn't work it must be something hardware related, whatever the case, I'd take it back to where you got it and see if they can at least supply you with a replacement battery so you can try this out...
Good luck,
M.
proton24 wrote:The battery life indicator on my 6600 is not refreshing itself. It always shos a full bar status even if the battery is about to run out. It only refreshes itself if you switch off & on the phone. Any idea why ? Is the the battery or the phone ? :dontknow: :frown:
Try it with a different theme before you format,(small chance,but worth a go).
Please dont reply in such massive writing,i nearly fell off my chair!
elton wrote:Try it with a different theme before you format,(small chance,but worth a go).Please dont reply in such massive writing,i nearly fell off my chair!
I switched to the default theme and it seems to be working fine. Thanks.
Sorry bout the font. First time posting here, didn't know a size 6 would be that huge. Thanks again.. 😊
dj_meerkat wrote:Hard to say, but I'd try and borrow another battery and see if that performs any differently, if not, it's more than likely the phone. Formatting, if you don't have too much stuff to lose at the moment, will probably clear it up if it's a software thing, it sounds like the phone isn't 'polling' the battery like it's meant too.If a format doesn't work it must be something hardware related, whatever the case, I'd take it back to where you got it and see if they can at least supply you with a replacement battery so you can try this out...
Good luck,
M.
Thanks for the feedback ... 😊
No worries. 😊
Glad it worked,hope you read this before you took dj_meerkat's advice?
