:con? :con? :con? :con? there not just quite thou i cant actually hear it, just a bout if i put speaker near ear. i have had a wave as a ringtone before and worked fine but now im having trouble. im using 44,100hz. 16 bit or 8 (tried both) and mono, also tried stero even thou phone only supports mono..... i no its gona b summat real simple but just get my head around it can ne 1 help pease...tia
wav's as ringtones, y are mine sooo quiet?
I think nokia 6600 only capable of supporting up to 16,000 hz so more than that you are wasting space and try make it into 8 bit I dont think it have any difference if you convert more than that. How about trying OGG files in my opinion it is better than Wav files just go and get OGG player and you're set as well as get a converter
cheers but i want the wav 4 a ringtone u cnt have ogg ringtones
