Don't use this code to format your Nokia 6630.
If you use it, you will have operating system problem!!
You have to format memory card too, and 6630 will works properly..
It is better make a backup of memory card, as soon as possible, because after the format, you will lost your data and programs.
pummette
Hey i also formatted my phone using the *7370# code and im having software problems..
Please tell me how to solve this problem..
What should i do??
What are the problems you people encounter?
And if you backup your data to memory card and then restore what is the meaning of formatting phone memory? It will put back exactly the same files.
pummette wrote:Hi,Don't use this code to format your Nokia 6630.
pummette
i use that and i don't have any problems so far(i use *#7370# and *#7780#)
the bluetooth bcums really slow and the baklite isnt stable and sumtimes it is on and sumtimes nt..
I formatted it too, and:
1) Did not have problems. Actually phone is faster 😊
2) My mmc didnt lost any data.
Solutions:
Format again with FULL battery (or connected to power), and it should be good again..
Symbyan is like Windoows, sometimes you need to format sometimes to get it running good 😃
No problems after formatting here 😊
I still hav problems..
Can somebody plzz help me.. M sure dere must b sum professionals here..
i cnt send things ova ma bluetooth n dnt get d image uploader menu in images..
Help Somebody..!!
sehejsahni wrote:I still hav problems..
Help Somebody..!!
I suppose the phone doesn't understand your "cool" spelling :tongue:
UA
I want to format my phone memory. I formatted it using code *#7780#. It formatted. But i can't see any change. There changed only profiles. Now i am running on low memory. I want my phone full memory 10MB. How could I format my phone nokia 6630? 🙄
rohana1985 wrote:I want to format my phone memory. I formatted it using code *#7780#. It formatted. But i can't see any change. There changed only profiles. Now i am running on low memory. I want my phone full memory 10MB. How could I format my phone nokia 6630? 🙄
try pressing simultaneously the green button and * and 3, this will do a hard reset
format your MMC first
then do the hard reset
Tried the *#7370# trick on my Orange 6680 - didn't have any (more) problems after doing it, and didn't need to format my memory card 😊
Wirelessly posted (NOKIA 6630: Nokia6630/1.0 (2.39.151) SymbianOS/8.0 Series60/2.6 Profile/MIDP-2.0 Configuration/CLDC-1.1)
Iv done format on 6630 3 times (had it frm december) and frm day 1 its b
