Alternative email client (supporting SSL)
1 replies · 6,009 views · Started 17 November 2004
Hi.
I've always used the standard email client on my 6600 and it's been great. However, I now need to custom-define my POP3 & SMTP ports, and use SSL. I can't find any alternative email clients which a) can offer these features or b) if they can they're not very good...
I had a look at EmailView from Reqwireless - I just don't know why it's so popular. It does work, but I find it incredibly clunky. I.e. to compose an email, there are seperate screens/menus for each of To., Subject., [b]cc. and body headers. Yuk!
I also had a look at Profmail (or Profimail?) but found I couldn't customise it enough (no SSL I think).
Those 2 are basically it as far as alternatives go at Handango. I've searched high and low on Google and here, but I simply can't find one. Surely there's a company who's made a "killer" email app?
Any advice welcomed 😊
Cheers then
Will
Will
Did you try the latest Profimail ? Its 1.24 I think. It is said to have SSL. Trt the trial version.
