Hide icons in Nokia 6600
8 replies · 4,253 views · Started 18 November 2004
Hi all,
I want to hide a particular icon in my 6600 menu screen. For example lets say i want to hide camera application icon from the menu but i want to access that particular application using a file manager like seleQ. How can do this...? If its to be done by an software, what is the software name. Pls help.
Regards:
Elvis 😊
I would just create a new folder and tuck any programs I don't use that much in there, and then move it to a position at the bottom of the menu.
lakeywhite wrote:I would just create a new folder and tuck any programs I don't use that much in there, and then move it to a position at the bottom of the menu.
Well, after I read your post. I smile,..... then keep on laughing,.... and laughing.... (on offend, mate!)
What a brilliant idea you have there! because,.... I did the same as you! 😃 One problem is, some time I want to hide something from kids! 😡 But with this, finally it still can be found, if the kids scroll down!
[QUOTE=elvisx77]Hi all,
Regards:
rajesh
rajesh_se wrote:[QUOTE=elvisx77]Hi all,
Regards:
rajesh
As far as we know you cannot hide icons like you can in windows, please read the entire thread for the answers given.
elvisx77 wrote:I want to hide a particular icon in my 6600 menu screen. For example lets say i want to hide camera application icon from the menu but i want to access that particular application using a file manager like seleQ. How can do this...? If its to be done by an software, what is the software name. Pls help.
I just notice that there is one application called "ActiveTodayS60 Version 2".
So, using that you can by pass the normal Nokia main menu screen. I mean there is a setting that you can set it off(No more menu screen!). Then just put in any shoctcut icon you want! Does that solve your problem? Please try to find that software with google for more information!
best regards,
its easy to do it, all menu icons, except the apps of the Z drive.
u need seleQ or fileman
