Transfer SMS Messages to PC
7 replies · 16,932 views · Started 18 November 2004
I have around 500 saved messages on my nokia ngage and i am looking for a way to transfer them and display them on, and possibly print them from my computer. i have a bluetooth adapter.
does anyone know of an application or a way to do this?
Any help would be appreciated.
Many Thanks
Chris 😉
lchris006 wrote:I have around 500 saved messages on my nokia ngage and i am looking for a way to transfer them and display them on, and possibly print them from my computer. i have a bluetooth adapter.
Many Thanks
Chris 😉
Tried it and couldn't, there doesn't seem to be a way. But nevertheless look at the sotware shop, you may be lucky!
Dude....try this
use a File Explorer..for this
go to c:\system\
over there u will see this folder call Mail
(the complete path .. c:\system\mail )
Copy the whole Mail folder thru Bluetooth to ur PC (using PC suite)
when ever u want to recover ur SMSs...just Replace the Original folder with this folder...and u will get all ur MSGS 😊
I did try that some time ago, but the phone just did not let me, it said the file was being used all the time. thanks anyway, maybe I did not do it correctly.
Many Thanks
Chris 😉
Hi there,
I think i got the solution for u. Go get this software called MsgStorer from www.symbianware.com
install it and you will be able to export selection/all your messages into txt file. Then you can send the txt file to your computer via BT. Once it reach your PC, use WORDPAD to open the file. Dont use NOTEPAD.
Hope that helps .. 😊
mikeeeee wrote:Hi there,
Euhm... but you have to buy this???
Wirelessly posted (NOKIA: Nokia3120/1.0 (05.30) Profile/MIDP-1.0 Configuration/CLDC-1.0)
Msgstorer, msgsaver are good app. But need to buy it.
gamefunky wrote:Dude....try this
go to c:\system\
after copying the whole folder, can you transfer its contents to another symbian phone so that you can read the saved messages there?
