Recently PsiNT released a new, much improved version of Extended
Profiles application for the Nokia 7650.
Changes in version 1.20F:
- Extended Profiles now provides the user with advanced profile
management and customisation functions:
- one can select a background image to be assigned to each profile
- assign color palette to each profile
- assign screen saver to each profile (fully compatible with Screen
Saver application)
- time of inactivity after which screen saver is activated
- each profile can be assigned with different key functions
- cosmetic changes
About Extended Profiles
Extended Profiles adds important function missing in Nokia 7650:
scheduling profile changes and customising profiles with many options
unavailable in default "Profiles" application.
Extended Profiles application provides the user with advanced profile
- you can select a background image to be assigned to your profile
Saver application)
- you can change functions of left and right selection buttons located
below the screen
Extended Profiles enables you to automatically switch the profiles of
your Nokia 7650. You can simply select time, required profile and
weekday (daily, working days, weekend etc.) - Extended Profiles will do
the rest: switch and activate the profile automatically at the scheduled
time.
Extended Profiles supports all standard profiles as well as customized
ones.
You can find more detailed information and download trial version of
Extended Profiles at http://psiloc.com/
