😊 Hi guys from India please give your operator, phone type and whether you are using GPRS or not...
Just to know 😃 Please respond..
I am from Kerala, Using 6600 on BSNL Mobile. GPRS Activated. :icon14:
Try to contact your network operator and they will provided you the settings.
eBast wrote:😊 Hi guys from India please give your operator, phone type and whether you are using GPRS or not...Just to know 😃 Please respond..
I'm in Kolkata with airtel. Airtel provides both a free gprs (airtel live) and a 99/- buck one. . .
i cant manage to use opera with airtel... and havent tried with hutch. the customer care have no idea at all what opera is - most of them repeat save the settings -.
rohitkhannak wrote:I'm in Kolkata with airtel. Airtel provides both a free gprs (airtel live) and a 99/- buck one. . .
Is your phone 6600 ? Are you using GPRS regularly ? Why cant you use Opera ? Have you entered Port number in Advanced settings ? :icon14:
no, i have a nokia 3650, but all the same i still should be making opera work even if i had a 6600. i use GPRS (the free one as described previously) pretty frequently but i have to tweak it to make it work faster - i have to keep the "connection security" on to make as fast as Hutch's GPRS (hutchworld). The port no. (as given by airtel) is 8080, but after connecting to server comes, nothing loads.
Actually the other GPRS offered by airtel might work with opera because it provides full browsing on computer, but as i have the free one, which works pretty well with the built-in browser, i dont have much probs.
rohitkhannak wrote:Actually the other GPRS offered by airtel might work with opera because it provides full browsing on computer, but as i have the free one, which works pretty well with the built-in browser, i dont have much probs.
Did you try your luck with the 6.2 version of Oprera ? That might work for you. The link is .... Opera 6.20
gprs on bsnl???whn did tht start?is it in kerala only or all over india?i live in west bengal and i just cant get 2 the customer service...coz everytime i try 2 call thm...a msg comes..."plz check the no. u hav dialled!!!"so can u plz temme how 2 activate gprs on bsnl?
nope, i downloaded opera 6.20 .... doesnt work.
6600user_sumit wrote:gprs on bsnl???whn did tht start?is it in kerala only or all over india?i live in west bengal and i just cant get 2 the customer service...coz everytime i try 2 call thm...a msg comes..."plz check the no. u hav dialled!!!"so can u plz temme how 2 activate gprs on bsnl?
Yes it is true 😉 See Link Here . They have started service all over India except Pune it seems. Settings they will send you via service message when your connection is activated.
Customer service .... you have to call them at early hours like 4 am 😃
rohitkhannak wrote:nope, i downloaded opera 6.20 .... doesnt work.
Have you tried Netfront ? Its a pretty good browser and they give 45 days free trail also.....
eBast wrote:Yes it is true 😉 See Link Here . They have started service all over India except Pune it seems. Settings they will send you via service message when your connection is activated.Customer service .... you have to call them at early hours like 4 am 😃
6600user_sumit wrote:ya i hav seen this link...but it doesnt tell how 2 activate gprs...and i just get 2 the operator!btw,mine is a prepaid connection...can sum1 plz temme how 2 get gprs activated 4 bsnl?
BSNL has started GPRS only for its post paid customers at present. But you can get details of the settings and activation HERE . 😊
ok thnx 4 the info...i went 2 the same link yest and tried setting it,but it wasnt able 2 connect....ne news abt whn its activating 4 prepaid?nothing like tht is mentioned in this link!
6600user_sumit wrote:ok thnx 4 the info...i went 2 the same link yest and tried setting it,but it wasnt able 2 connect....ne news abt whn its activating 4 prepaid?nothing like tht is mentioned in this link!
Naturally you will be able to connect only after you have activated the GPRS, for which you have to give a written request at your nearest Customer Servive Center.
Opera will never work if you havn�t set up the connection proparly!
1. Contact you service provider and get your subscription prepared for INTERNET surfing. WAP-content won�t do it!
2. Set up the phone to the certain internet acces point that is activated on yopur account. Opera has set up a nice page with many of the settings that you need to get connected. See this page:
http://www.opera.com/products/mobile/docs/connect/
If you cant surf with Opera, Netfront will not work either, so there is no reason to spend much time downloading Netfront.
Good luck!
me from delhi, Hutch with 6600 and yeah grps activated and opera works.
Siddharth wrote:me from delhi, Hutch with 6600 and yeah grps activated and opera works.
What settings have you used in Advanced Settings ? Phone IP, Primary Name server, Secondary Name server, Proxy server, Proxy Port etc .
And what average speeds are you getting ? kbps ? 😊
Are you using HutchWorld or HutchWWW??
eBast wrote:What settings have you used in Advanced Settings ? Phone IP, Primary Name server, Secondary Name server, Proxy server, Proxy Port etc .And what average speeds are you getting ? kbps ? 😊
the adv settings are as follow
phone ip address : Automatic
Primary name server : 0.0.0.0
Secondary Name Server : 0.0.0.0
Proxy Server Address : 10.10.1.100
Proxy Port Number : 9401
and also in opera go to
Settings ==> Advanced and than
enable proxy : on
HTTP Proxy Host : 10.10.1.100
HTTP proxy Port : 9401
These are the setting which work for me.
rohitkhannak wrote:Are you using HutchWorld or HutchWWW??
whatz the difference...?
i pay 99Rs for gprs and mms together.
Wirelessly posted (Nokia3650/1.0 SymbianOS/6.1 Series60/1.2 Profile/MIDP-1.0 Configuration/CLDC-1.0)
If u pay 99 bucks per month, then its hutchworld you're using. Actually hutchwww allows you access on internet as well (i think!). I know for sure hutchworld doesnt allow access on the comp.
Any IDEA subscriber here (Delhi) ?
I think IDEA dosnt allows GPRS for Prepaid subscribers. So i guess, i would have to surf net through my PC's bluetooth connection...
regards,
makuchaku
makuchaku wrote:Hi,So i guess, i would have to surf net through my PC's bluetooth connection...
regards,
makuchaku
Are you talking about browsing on the phone using PC's internet conenction ? Is it possible ?
Opera works now!!
Thanks Siddarth, for the settings! I didnt know you had to input something in the HTTP Proxy Host!
rohitkhannak wrote:Opera works now!!
nice 2 hear
has ne1 of u tried gettin ur firmware updated?whr do i take my fone 2 get tht done in india...i live near calcutta!
Hii there
I am frm Nagpur , 6600 and BSNL, no GPRS! 😞
GPRS has not been intorduced in Pune and also in Nagpur, as both are in same circle!
btw, tht unlimited plan of GPRS ( 349 plan ) ? will I be able to connect my PC thru my 6600's GPRS and surf?
and wht does P2P and M2P mean?
to 6600user_sumit :
You can call Nokia Care - (30303838). I also live near Kolkata. You can try at the Park Street Nokia Professional Center abt updating firmware - but I doubt whether they can help you.
