When i click on 'Add track' in audio manager, it will let me bring up any music i have (either disk or har drive etc) but when i click on one to add nokia suite just crashes. I have re installed it iver and over again but still having no luck. An help would be appreciated as i cant get any music onto my phone.
I have a nokia 6670 btw
Which version? The one with PC Suite 6.4 (http://www.nokia.com/pcsuite) or something older?
I presume you meant the version of pc suite? If this is an old version why is it supplied with the phone, i only got it last week! Will download 6.4 now and see if the sorts it
I think the one on the CD is 6.1. Actually 6.3 seems the best version. I am having a lot of problems with 6.4 - PC slowdown, boot time increase, runtime errors/low level driver errors everytime I disconnect the phone, individual app. hangs, icon not appearing in systray at times, etc. I had no problems with 6.0. I simply cannot understand why Nokia has to run all the apps as services.
I am going to try uninstalling 6.4 and using the CD version if this continues.
Well my cd version just would not work as it should have. The 6.4 i downloaded now works fine and i have had no problems (touch wood!).
That's good to hear. 6.4 works fine for me, too, whereas I had some issues with the previous versions.
