Why is this happenin????
4 replies · 1,254 views · Started 20 November 2004
hi guys. i bought my 3650 about 5 months back. i have a 128 mb card. i installed a lot of apps and games on my phone since then. a few days ago, my phone just went dead. when i turned it on, it displayed the message 'System Error' and a few Psiloc apps werent working. everything else was working fine. i uninstalled these apps and restarted my fone. the same message appears at startup everytime, although everything else works fine. its damn annoying. can anyone help?
You could back it up before. Its the easiest method.
You could analyze which program causes the message but that is difficult takes time
Wirelessly posted (Nokia3650/1.0 SymbianOS/6.1 Series60/1.2 Profile/MIDP-1.0 Configuration/CLDC-1.0)
When u had to fully uninstall wildskinz, u had to delete the system.ini file from drive c. That way, no system error message came on startup. Maybe you could do that as a solution. But do it at your own risk, because your phone might not work after deleting the file, and starting up. So beware if you try to attempt this.
