Can't connect serial port with MSI bluetooth dongle
6 replies · 3,760 views · Started 12 October 2002
Anyone else had this problem? I can't connect the serial bluetooth port, but can connect the fax or the dial up networking. I am thinking of taking my 7650 to the nokia service center, but wondered if anyone else had the same problems. I've tried the drivers that came with the adapter, the latest ones from the msi site, etc... No change.
I think you have the same problem as I. When you connecting bluetooth via serial port you will get a message "The Bluetooth Serial Port connection failed: The remote device closed the connection.". With this message it seem that the bluetooth isn't connected. But, if you look at the mRouter Icon at the status bar. It will show connected. You just run you pc suite it will work.
Then you're luckier than me. I get the message, and mrouter keeps claiming it isn't connected... 😞
No it is alright if it refuses to connect in one Com try to check every other one, by me its always the 2 coms after the one that refuses so in your case 6 and 7, however try them all!
