Start-UP FAILD
3 replies · 2,395 views · Started 20 November 2004
Hi! , my nokia 7650 really crash. I was using the spacedoubler in my messages folder, after I check my messages the spacedoubler was compacting the info, but it never end, so I took out the battery of the phone, when I put it back and a turn on my 7650, it give the message: Phone start-up failed. Contact retailer.
Can any one help me please!!!!
Thanks!
This Topic Has Disscused before
Well you have to do wht your phone says "Contact The Retailer"
It need a Re-Flash and all the data will deleted.
Thanks for de advice!
But is possible to reflash the phone by my self?
I don�t care about loose my information, I already backup all the data.
No You Can't you need some advance tool which can get only on NSC and Other Prof Center.
So u can't Reflash by ur self.
