Notes in folders
0 replies · 1,457 views · Started 21 November 2004
Just got my 6260 and am dismayed to see it has the same limitation as the 7650 had: You can't sort notes into folders.
I use the default Notes application for jotting down all sorts of stuff I need to remember. Since this is a lot of stuff, I want to sort the notes into folders depending on contents.
Anyone know of an application that can do this? I don't need any fancy text formatting or anything like that, just a simple text editor which will let me save text files into different folders of my choice.
Thanks,
Gunnar
