Painting a 7650
3 replies · 1,611 views · Started 12 October 2002
Has anyone out there painted their 7650?
I'd like to paint mine but I'm a bit unsure of how to do it so that it looks good and lasts well in normal everyday use. ie what kind of paint and tools should I use etc.
Any advice?
Max
http://www.allabouter6.com/phpBB2/viewtopic.php?t=2424&highlight=hardware
here is the link to a thread in this forum discussing hardware, and the guy (millenium) painted his 9210 black i think! you can PM him! But I dont think you will get an answer anyways since he hase not pasted since a long time now!
I am not an expert on this but I think I can suggest a method. The external case for the nokia is available for change from your nokia service centre (should be around 14$US). If you can get one, then you can spray paint that (mettalic would be nice I guess). Just make sure you apply the right masks for the lcd screen etc.. Once you are done, you could ask NSC to change the cover for you...
Please keep us informed if you get this done. 😉
[quote="Anonymous"]I am not an expert on this but I think I can suggest a method. The external case for the nokia is available for change from your nokia service centre (should be around 14$US). If you can get one, then you can spray paint that (mettalic would be nice I guess). Just make sure you apply the right masks for the lcd screen etc.. Once you are done, you could ask NSC to change the cover for you...
Please keep us informed if you get this done. 😉[/quote]
Oops That was me. 😊..
