Hey guys! I just bought a Nokia 6670 3 days ago and I can't find any Netfront browser and quickoffice in it. Instead it contains an Opera Brower.... I've searched it on Nokia PC sute but it also does not have netfront and quickoffice installation files. Do you have any idea where it is located? or where can i get an installation file? thanks!
Please help!!! Netfront browser and quickoffice is missing!
I just bought a 7610 and found most of the applications on the memory card. Nokia usually puts them on the memory card and once you install it, the apps are ready to use. I suggest you take a full backup of your original memory card using a card reader to your PC, 'just in case...' If it is not on the memory card, you may have got a 7610 MMC card by mistake? Then you need to contact Nokia service for this.
ok thank you very much. 😊
michaelglim wrote:Hey guys! I just bought a Nokia 6670 3 days ago and I can't find any Netfront browser and quickoffice in it. Instead it contains an Opera Brower.... I've searched it on Nokia PC sute but it also does not have netfront and quickoffice installation files. Do you have any idea where it is located? or where can i get an installation file? thanks!
Did you reformat your original rs-mmc card?All system application for netfront browser is storage in Rs-mmc ...If you have original rs-mmc you might able to transfer with your pc suite 6.4 using back file as netfront/quickoffice is 3rd party software.
Ellow All!
Hmmm... can I know the complete list of apps on the rs-mmc of new 6670? I traded my original card with 256mb so I don't have the chance to try em!
I change my memory card to a 256 too, I copy and paste everything from one card to another, but nothing is there...
Try to get it on Nokia site at 6670 section.
