Little things
1 replies · 1,377 views · Started 22 November 2004
Hi, just wondering is anyone else experienceing problems with realplayer. I have encoded a few television programs using the nokia pc suite softare and have replayed the programs on my phone. The problem seems to be that there is a little sound delay, and the longer the program goes on the longer the delay.
Also is it just my phone or does the 7610 take long to boot up. I have had 3 nokias previous and my last phone was a T610 and none of them took even half the length of this phone.
It seems like this problem could be caused by the way the files are encoded or possibly that Realplayer does not support the format or does not have the correct decoder installed in order to sync the voice with the picture.
I personally use Smartmovie and never have any problems.
As the 7610 is symbian based and therefore is like a mini computer it takes longer to start up then normal phones, mine is the same.
