Hi I installed OggPlay on my 6600 so that I could use .Ogg files for my ringtones. They now play fine in the ringtone select menu but when someone rings me or its used as an Alarm Tone it does not go off. Any ideas people ?
Using .Ogg files as a Ringtone.
Just incase anyone else has the same problem I have found a way to do it:
Install: OggPlay-S60-MMF.1.6.3
1.6.2 or lower did not work for me.
Thats with Firmware: V 4.09.1
It played the .Ogg files fine after installation but didn't play them as a ringtone until I restarted the phone 😊
Nogimics wrote:Just incase anyone else has the same problem I have found a way to do it:Install: OggPlay-S60-MMF.1.6.3
I have OggPlay version 1.6.2 stable,and I can use .ogg files as an alarm tone without any problems.Fw 5.27.0
