installed app not showing in menu
9 replies · 4,962 views · Started 22 November 2004
i just installed an application on my 6600 and its not showing in the menu.the log in the manager shows it as installed but the manager doesnt show it in the list of installed applications.i also tried searching for it in the file manager but i cant find it thr also.i installed it the fone memory and after i installed it,its showing lesser free memory.can sum1 plz guide me on how to use/remove this application?ope its not a virus!!
What application was it (name, version and name of installation file would be nice to know, and also where did you download it from; assuming it is a legal copy - if not, don't post any links)?
it was some stupid adult game called frost ver.0.00(nice version no.)donno if it was legal or not...i downloaded it from a site called imserba.com..its name given thr is sexy chicks
That happened to me a few times on my 3660...did you try and reboot the phone and then see if it appears?
Mixrdrivr wrote:That happened to me a few times on my 3660...did you try and reboot the phone and then see if it appears?
yaa i hav tried all tht...not appearing!😞
6600user_sumit wrote:yaa i hav tried all tht...not appearing!😞
Where did you install into MMC or Phone Memory ? Try to delete the files using FExplorer.
eBast wrote:Where did you install into MMC or Phone Memory ? Try to delete the files using FExplorer.
i tried installing both on phone memory as well as mmc...i tried searching 4 its files using filemanager but i cant find ne files wid tht name...but the it is taking some 100 kb of memory!i scanned my fone using f-secure..its not a virus atleast!
ya man that happned with me too!!
i downloaded the same file from the same site and after installing it the icons dont apper!!!
Mad_dog wrote:ya man that happned with me too!!
lemme know if u find ne solution 2 this!
