Terminal application for 9210
4 replies · 2,938 views · Started 11 December 2001
Hi!
The 9110 had an application on it called terminal.
I used that application to call up a BBS (like hyper terminal on a PC).
The problem is that the 9210 does not have this application, and I have not been able to find it or another application that does the job myself. There seems to be a bunch of telnet applications, but none that works like hyper terminal, that can call up another computer.
If there is anyone out there who can help me out with this one?
/Jonas
Thanks Manowar, but I have allready looked at the sites you mention (and a bunch of others too). All I have found is terminal applications that uses IP or serial communication. I havent found one supporting modem connection directly, like Hyper Terminal does.
Rafe, do you know if there is any application that supports this under development? And do you know why they took the terminal application away when they made the 9210?
/Jonas
You can use newdialing program from www.my-communicator.com
<TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote</font><HR></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>
/Jonas
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR></TD></TR></TABLE>
